주요 콘텐츠로 건너뛰기
HP Spectre 13-4002dx Display Replacement
필요한 것
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: 1 단계, 이미지 1/3 HP Spectre 13-4002dx Display Replacement, Motherboard: 1 단계, 이미지 2/3 HP Spectre 13-4002dx Display Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: 2 단계, 이미지 1/1
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: 3 단계, 이미지 1/2 HP Spectre 13-4002dx Display Replacement: 3 단계, 이미지 2/2
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: 4 단계, 이미지 1/2 HP Spectre 13-4002dx Display Replacement: 4 단계, 이미지 2/2
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
결론
Aidan
회원 가입일: 02/20/20
105 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 437
