주요 콘텐츠로 건너뛰기
HP Spectre 13-4002dx Heat Sink Replacement
필요한 것
  1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: 1 단계, 이미지 1/2 HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Heat Sink Replacement: 2 단계, 이미지 1/2 HP Spectre 13-4002dx Heat Sink Replacement: 2 단계, 이미지 2/2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: 3 단계, 이미지 1/3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: 3 단계, 이미지 2/3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: 3 단계, 이미지 3/3
    • Remove the tape outlined in red.
    • The tape can tear easily.
  4. HP Spectre 13-4002dx Heat Sink Replacement: 4 단계, 이미지 1/2 HP Spectre 13-4002dx Heat Sink Replacement: 4 단계, 이미지 2/2
    • Remove the four 3 mm screws using a Phillips #0 screwdriver.
  5. HP Spectre 13-4002dx Heat Sink Replacement: 5 단계, 이미지 1/1
    • Remove the heat sink from the laptop.
결론
Cayce Stewart
회원 가입일: 01/16/19
725 평판
안내서 6개 작성하였습니다
University of Alabama, Team S1-G4, Bedsole Spring 2019 University of Alabama, Team S1-G4, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 264
