주요 콘텐츠로 건너뛰기
HP Spectre 13-4002dx Motherboard Replacement
필요한 것
  1. HP Spectre 13-4002dx Motherboard Replacement, Bottom Case: 1 단계, 이미지 1/2 HP Spectre 13-4002dx Motherboard Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Motherboard Replacement: 2 단계, 이미지 1/2 HP Spectre 13-4002dx Motherboard Replacement: 2 단계, 이미지 2/2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Motherboard Replacement, Battery: 3 단계, 이미지 1/3 HP Spectre 13-4002dx Motherboard Replacement, Battery: 3 단계, 이미지 2/3 HP Spectre 13-4002dx Motherboard Replacement, Battery: 3 단계, 이미지 3/3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Motherboard Replacement: 4 단계, 이미지 1/3 HP Spectre 13-4002dx Motherboard Replacement: 4 단계, 이미지 2/3 HP Spectre 13-4002dx Motherboard Replacement: 4 단계, 이미지 3/3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Motherboard Replacement: 5 단계, 이미지 1/2 HP Spectre 13-4002dx Motherboard Replacement: 5 단계, 이미지 2/2
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Motherboard Replacement: 6 단계, 이미지 1/3 HP Spectre 13-4002dx Motherboard Replacement: 6 단계, 이미지 2/3 HP Spectre 13-4002dx Motherboard Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Motherboard Replacement: 7 단계, 이미지 1/1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Motherboard Replacement, Motherboard: 8 단계, 이미지 1/3 HP Spectre 13-4002dx Motherboard Replacement, Motherboard: 8 단계, 이미지 2/3 HP Spectre 13-4002dx Motherboard Replacement, Motherboard: 8 단계, 이미지 3/3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
결론
Dillon Wagers
회원 가입일: 02/11/20
73 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 461
