주요 콘텐츠로 건너뛰기
HP Spectre 13-4002dx SD Card Reader Replacement
필요한 것
  1. HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: 1 단계, 이미지 1/2 HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx SD Card Reader Replacement: 2 단계, 이미지 1/2 HP Spectre 13-4002dx SD Card Reader Replacement: 2 단계, 이미지 2/2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx SD Card Reader Replacement, Battery: 3 단계, 이미지 1/3 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: 3 단계, 이미지 2/3 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: 3 단계, 이미지 3/3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx SD Card Reader Replacement: 4 단계, 이미지 1/3 HP Spectre 13-4002dx SD Card Reader Replacement: 4 단계, 이미지 2/3 HP Spectre 13-4002dx SD Card Reader Replacement: 4 단계, 이미지 3/3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx SD Card Reader Replacement: 5 단계, 이미지 1/2 HP Spectre 13-4002dx SD Card Reader Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx SD Card Reader Replacement: 6 단계, 이미지 1/3 HP Spectre 13-4002dx SD Card Reader Replacement: 6 단계, 이미지 2/3 HP Spectre 13-4002dx SD Card Reader Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx SD Card Reader Replacement: 7 단계, 이미지 1/1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: 8 단계, 이미지 1/3 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: 8 단계, 이미지 2/3 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: 8 단계, 이미지 3/3
    • The SD Card Port is located in the red box.
    • Remove the one PH0 30 mm screw circled in red.
  9. HP Spectre 13-4002dx SD Card Reader Replacement: 9 단계, 이미지 1/1
    • Remove the connector outlined in red.
  10. HP Spectre 13-4002dx SD Card Reader Replacement: 10 단계, 이미지 1/3 HP Spectre 13-4002dx SD Card Reader Replacement: 10 단계, 이미지 2/3 HP Spectre 13-4002dx SD Card Reader Replacement: 10 단계, 이미지 3/3
    • To unlock the ribbon cable, lift the white flap on the ZIF connector 90 degrees.
    • Slide the ribbon cable out of the connector.
  11. HP Spectre 13-4002dx SD Card Reader Replacement: 11 단계, 이미지 1/1
    • Remove the SD Card Port.
결론
Cayce Stewart
회원 가입일: 01/16/19
725 평판
안내서 6개 작성하였습니다
University of Alabama, Team S1-G4, Bedsole Spring 2019 University of Alabama, Team S1-G4, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 249
