주요 콘텐츠로 건너뛰기
HP Spectre 13-4002dx Vent Fan Replacement
필요한 것
  1. HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: 1 단계, 이미지 1/2 HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Vent Fan Replacement: 2 단계, 이미지 1/2 HP Spectre 13-4002dx Vent Fan Replacement: 2 단계, 이미지 2/2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: 3 단계, 이미지 1/3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: 3 단계, 이미지 2/3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: 3 단계, 이미지 3/3
    • Remove the strip of black electrical tape.
    • Pull the tape away from the vent fan.
    • Pull gently, as the tape is easy to rip.
  4. HP Spectre 13-4002dx Vent Fan Replacement: 4 단계, 이미지 1/2 HP Spectre 13-4002dx Vent Fan Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
  5. HP Spectre 13-4002dx Vent Fan Replacement: 5 단계, 이미지 1/3 HP Spectre 13-4002dx Vent Fan Replacement: 5 단계, 이미지 2/3 HP Spectre 13-4002dx Vent Fan Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect the wire connection between the laptop and the vent fan.
  6. HP Spectre 13-4002dx Vent Fan Replacement: 6 단계, 이미지 1/1
    • Remove the vent fan.
결론
Cayce Stewart
회원 가입일: 01/16/19
725 평판
안내서 6개 작성하였습니다
University of Alabama, Team S1-G4, Bedsole Spring 2019 University of Alabama, Team S1-G4, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Any idea what model# the fan is?
ayekay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 283
