주요 콘텐츠로 건너뛰기
HP Spectre Pro X360 G1 Battery Replacement
필요한 것
  1. HP Spectre Pro X360 G1 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off and unplug the laptop.
    • Flip the laptop so that the backplate is exposed.
  2. HP Spectre Pro X360 G1 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the eight screws with the T5 Torx screwdriver.
  3. HP Spectre Pro X360 G1 Battery Replacement: 3 단계, 이미지 1/1
    • Using the plastic opening tools carefully lift the backplate.
  4. HP Spectre Pro X360 G1 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the 4 screws holding down the battery with the Phillips #1 screwdriver.
  5. HP Spectre Pro X360 G1 Battery Replacement: 5 단계, 이미지 1/2 HP Spectre Pro X360 G1 Battery Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to disconnect the wires.
  6. HP Spectre Pro X360 G1 Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery off of the alignment pins on the top cover and remove it from the device.
결론
Alexis Garcia
회원 가입일: 02/13/20
183 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 32
전체 시간: 1,518
