소개
A faulty battery could be the reason for the laptop not turning on. If you are certain that the battery needs to be replaced, follow this guide to replace the battery.
필요한 것
Make sure the device is powered off and the kick stand is retracted.
The HP Spectre should be placed on a flat surface with the keyboard detached.
To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
Podrían subir el procedimiento para despegar los clip, ? al parecer viene pegada la pantalla a la carcasa, en ese caso se usaría la pistola de calor o estoy mal ? Al guíen que me guié por favor, agradezco de antemano
다른 4명이 해당 안내서를 완성하였습니다.
댓글 17개
Awesome, thanks a lot! My old Spectre’s battery now only supports less than 2 hours, wish I could replace it with a new one.
Clear - Complete - Accurate instructions led me through the successful replacement. glad I found this. Good Job.
Did the screen crack for you
Tiffany -
I cracked my screen during step 3. There are adhesive strips at the bottom of the screen and you do not want to flex the screen to pull it away from the strips. Just take your time and don’t put too much stress on your screen.
Also, I skipped steps 4-6. The battery was there and no need to remove that cable. Good Luck
@ Jay Mac, I purchased a deadstock HP battery off ebay for $26 shipped. I was skeptical, but it works and I get 8 hours of screen time out of it.
Hello, can you recall where did you buy battery from?
thanks
Hi, Yes the screen did crack for me.. i order from the supplier oversea, $145 for brand new one. so sad
Where can I purchase the replacement battery?
Got a Battery off e-bay and replaced, but something needs to be done for bios to see it. Battery works and says 100% charged, 225% in the control panel icon but the machine hibinates after about 10 mins, wake the machine up sausys 92% charged. Most of the HP diagnostics don’t recognise the battery even thought it works and is installed.
thanks for the heads up with the adhesive strips I ran a heatgun @ 100degrees_c along the bottom edge and under the kick stand
used gravity and the adhesive strips melted like butter screen came off no cracks, breaks or problems
My screen did not break
Replaced the battery without any difficulty. I am now getting a battery not found error. This is the 2nd battery that cannot be recognized. Where can I get a battery that works and is recognized by the computer?
thanks for this course.My spectre X2,has been used 7years,now ,ti couldnt use more than 1 hour.I need replace its baterry.
