주요 콘텐츠로 건너뛰기
HP Spectre x360 13-4103dx Back Panel Replacement
필요한 것
  1. HP Spectre x360 13-4103dx Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Back Panel Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Back Panel Replacement: 3 단계, 이미지 1/1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
결론
Andrew Medeiros
회원 가입일: 10/25/21
511 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 605
