주요 콘텐츠로 건너뛰기
HP Spectre x360 13-4103dx Touch Pad Replacement
필요한 것
  1. HP Spectre x360 13-4103dx Touch Pad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Touch Pad Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Touch Pad Replacement: 3 단계, 이미지 1/1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
  4. HP Spectre x360 13-4103dx Touch Pad Replacement, Battery: 4 단계, 이미지 1/2 HP Spectre x360 13-4103dx Touch Pad Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
  5. HP Spectre x360 13-4103dx Touch Pad Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the computer.
  6. HP Spectre x360 13-4103dx Touch Pad Replacement, Touch Pad: 6 단계, 이미지 1/3 HP Spectre x360 13-4103dx Touch Pad Replacement, Touch Pad: 6 단계, 이미지 2/3 HP Spectre x360 13-4103dx Touch Pad Replacement, Touch Pad: 6 단계, 이미지 3/3
    • Remove the five screws from the trackpad using a Phillips #0 screwdriver.
  7. HP Spectre x360 13-4103dx Touch Pad Replacement: 7 단계, 이미지 1/1
    • Gently unplug the ribbon cable that is attached to the computer.
  8. HP Spectre x360 13-4103dx Touch Pad Replacement: 8 단계, 이미지 1/1
    • Remove the touchpad from the computer.
결론
Andrew Medeiros
회원 가입일: 10/25/21
511 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 30
전체 시간: 579
