주요 콘텐츠로 건너뛰기
HP Spectre x360 13-ac023dx Motherboard Replacement
필요한 것
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: 1 단계, 이미지 1/2 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: 2 단계, 이미지 1/3 HP Spectre x360 13-ac023dx Motherboard Replacement: 2 단계, 이미지 2/3 HP Spectre x360 13-ac023dx Motherboard Replacement: 2 단계, 이미지 3/3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: 3 단계, 이미지 1/2 HP Spectre x360 13-ac023dx Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: 4 단계, 이미지 1/1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: 5 단계, 이미지 1/2 HP Spectre x360 13-ac023dx Motherboard Replacement: 5 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: 7 단계, 이미지 1/1
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: 8 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: 9 단계, 이미지 1/2 HP Spectre x360 13-ac023dx Motherboard Replacement: 9 단계, 이미지 2/2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: 10 단계, 이미지 1/1
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: 11 단계, 이미지 1/3 HP Spectre x360 13-ac023dx Motherboard Replacement: 11 단계, 이미지 2/3 HP Spectre x360 13-ac023dx Motherboard Replacement: 11 단계, 이미지 3/3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: 12 단계, 이미지 1/3 HP Spectre x360 13-ac023dx Motherboard Replacement: 12 단계, 이미지 2/3 HP Spectre x360 13-ac023dx Motherboard Replacement: 12 단계, 이미지 3/3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: 13 단계, 이미지 1/2 HP Spectre x360 13-ac023dx Motherboard Replacement: 13 단계, 이미지 2/2
    • Carefully lift and remove the motherboard.
결론
Jonathan
회원 가입일: 10/21/19
486 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 29
전체 시간: 3,384
