주요 콘텐츠로 건너뛰기
HP Spectre x360 13-ac023dx WiFi Card Replacement
필요한 것
  1. HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: 1 단계, 이미지 1/2 HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx WiFi Card Replacement: 2 단계, 이미지 1/3 HP Spectre x360 13-ac023dx WiFi Card Replacement: 2 단계, 이미지 2/3 HP Spectre x360 13-ac023dx WiFi Card Replacement: 2 단계, 이미지 3/3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx WiFi Card Replacement: 3 단계, 이미지 1/2 HP Spectre x360 13-ac023dx WiFi Card Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx WiFi Card Replacement, WiFi Card: 4 단계, 이미지 1/1
    • Locate the WiFi card.
  5. HP Spectre x360 13-ac023dx WiFi Card Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  6. HP Spectre x360 13-ac023dx WiFi Card Replacement: 6 단계, 이미지 1/2 HP Spectre x360 13-ac023dx WiFi Card Replacement: 6 단계, 이미지 2/2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
결론
Jonathan
회원 가입일: 10/21/19
486 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 1,809
