주요 콘텐츠로 건너뛰기
HP Spectre x360 13t-4000 Bottom Cover Replacement
필요한 것
  1. HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/2 HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Bottom Cover Replacement: 2 단계, 이미지 1/2 HP Spectre x360 13t-4000 Bottom Cover Replacement: 2 단계, 이미지 2/2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Bottom Cover Replacement: 3 단계, 이미지 1/3 HP Spectre x360 13t-4000 Bottom Cover Replacement: 3 단계, 이미지 2/3 HP Spectre x360 13t-4000 Bottom Cover Replacement: 3 단계, 이미지 3/3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Carvalho
회원 가입일: 03/21/19
566 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 UMass Dartmouth, Team S2-G4, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Any idea for previous model like acxxxx? The 5mm screw aren't visible, bit it's like if they are there. The corners won't come out. Is the screws hidden deep under the rubber pad? Removed the rubber, do we need to somehow remove the plastic part on which the rubber pad are glued? If so how? They seems to be glued on
Ben - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 1,107
