주요 콘텐츠로 건너뛰기
HP Spectre x360 13t-4000 Hard Drive Replacement
필요한 것
  1. HP Spectre x360 13t-4000 Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 1/2 HP Spectre x360 13t-4000 Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Hard Drive Replacement: 2 단계, 이미지 1/2 HP Spectre x360 13t-4000 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Hard Drive Replacement: 3 단계, 이미지 1/3 HP Spectre x360 13t-4000 Hard Drive Replacement: 3 단계, 이미지 2/3 HP Spectre x360 13t-4000 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Hard Drive Replacement, Battery: 4 단계, 이미지 1/3 HP Spectre x360 13t-4000 Hard Drive Replacement, Battery: 4 단계, 이미지 2/3 HP Spectre x360 13t-4000 Hard Drive Replacement, Battery: 4 단계, 이미지 3/3
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/3 HP Spectre x360 13t-4000 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/3 HP Spectre x360 13t-4000 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Using a Phillips #000 screwdriver, unscrew the one 2mm screw located to the left of the hard drive.
    • With the screw undone, use a plastic spudger, lifting the hard drive from the left side. Once the hard drive is at an angle, pull the hard drive out.
결론
Brandon Carvalho
회원 가입일: 03/21/19
566 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 UMass Dartmouth, Team S2-G4, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Will the 500 GB replacement kit work? It is recommended on this post but looks as though it is only compatible with Macs?
Crucial MX500 500 GB SSD
Mackenzi Christenson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 22
30일 전: 67
전체 시간: 8,664
