주요 콘텐츠로 건너뛰기
HP Spectre x360 13t-4000 SD Card Reader Replacement
필요한 것
  1. HP Spectre x360 13t-4000 SD Card Reader Replacement, Bottom Cover: 1 단계, 이미지 1/2 HP Spectre x360 13t-4000 SD Card Reader Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 SD Card Reader Replacement: 2 단계, 이미지 1/2 HP Spectre x360 13t-4000 SD Card Reader Replacement: 2 단계, 이미지 2/2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 SD Card Reader Replacement: 3 단계, 이미지 1/3 HP Spectre x360 13t-4000 SD Card Reader Replacement: 3 단계, 이미지 2/3 HP Spectre x360 13t-4000 SD Card Reader Replacement: 3 단계, 이미지 3/3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: 4 단계, 이미지 1/3 HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: 4 단계, 이미지 2/3 HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: 4 단계, 이미지 3/3
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 SD Card Reader Replacement, SD Card Reader: 5 단계, 이미지 1/2 HP Spectre x360 13t-4000 SD Card Reader Replacement, SD Card Reader: 5 단계, 이미지 2/2
    • Remove the 2 mm long Phillips #000 head screw on the SD Card Reader.
    • Using a plastic spudger, release the pressure connector marked with the green rectangle by gently prying up from below.
    • Once the pressure connector is undone, the white ribbon cable connected to the SD Card Reader will pull out with no resistance.
    • With the ribbon cable disconnected and the screw out, the SD Card Reader will be free to remove and replace.
    • When replacing the SD Card Reader, ensure the ribbon cable is firmly secured in the pressure connector, with the metal contact points facing down towards the motherboard.
결론
Brandon Carvalho
회원 가입일: 03/21/19
566 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 UMass Dartmouth, Team S2-G4, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 673
