소개
This guide will instruct you on how to remove and replace the speakers. Replacement of the speakers may be necessary if the speakers are not outputting any sound or outputting a distorted sound.
필요한 것
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
With the backplate and battery removed from the device, remove the three 2mm screws using the Phillips #0 screwdriver.
