소개
This guide shows how to remove and replace the Wi-Fi card for the HP Spectre x360 15t-ap000 laptop.
The Wi-Fi card uses a standard M.2 2230 form factor with two U.FL antenna connectors. You can replace this card with any Wi-Fi card following that form factor.
필요한 것
Use a T5 driver to remove the following screws securing the back cover:
Six 4 mm-long screws
Two 7.8 mm-long screws
Use an opening tool or your fingers to pry up the back cover from the laptop.
Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
Gently pull the connector parallel to the motherboard to disconnect it.
Use your fingers or tweezers to peel the black plastic strip until you uncover the Wi-Fi card.
