주요 콘텐츠로 건너뛰기
HP Spectrex360 13-ac023dx Display Replacement
필요한 것
  1. HP Spectrex360 13-ac023dx Display Replacement, Battery: 1 단계, 이미지 1/2 HP Spectrex360 13-ac023dx Display Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectrex360 13-ac023dx Display Replacement: 2 단계, 이미지 1/3 HP Spectrex360 13-ac023dx Display Replacement: 2 단계, 이미지 2/3 HP Spectrex360 13-ac023dx Display Replacement: 2 단계, 이미지 3/3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectrex360 13-ac023dx Display Replacement: 3 단계, 이미지 1/2 HP Spectrex360 13-ac023dx Display Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectrex360 13-ac023dx Display Replacement, Display: 4 단계, 이미지 1/1
    • Lay the laptop flat on the table with the keyboard side facing the table and the motherboard facing up.
  5. HP Spectrex360 13-ac023dx Display Replacement: 5 단계, 이미지 1/3 HP Spectrex360 13-ac023dx Display Replacement: 5 단계, 이미지 2/3 HP Spectrex360 13-ac023dx Display Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #000 screwdriver, remove the four 1.0 mm screws that attach the display to the main body of the computer.
  6. HP Spectrex360 13-ac023dx Display Replacement: 6 단계, 이미지 1/3 HP Spectrex360 13-ac023dx Display Replacement: 6 단계, 이미지 2/3 HP Spectrex360 13-ac023dx Display Replacement: 6 단계, 이미지 3/3
    • Move the metal components that were just unscrewed out of the way to make a clear view of the two display connectors.
    • Flip up both latches that are found at the center of the computer's body where the wires connect to the motherboard. Then release the wires that attach to the display. This will separate the two main parts of the computer.
  7. HP Spectrex360 13-ac023dx Display Replacement: 7 단계, 이미지 1/2 HP Spectrex360 13-ac023dx Display Replacement: 7 단계, 이미지 2/2
    • Separate the display from the bottom half of the computer(motherboard).
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan
회원 가입일: 10/21/19
486 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
I couldn’t remove the display without removing the one speaker. In the pictures, you can easily see that he just bent the metal case at the hinge and pried it out.
Ryan Stauffer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 66
전체 시간: 2,510
