주요 콘텐츠로 건너뛰기
HP Split 13-r010dx Front and Back Panel Replacement
필요한 것
  1. HP Split 13-r010dx Front and Back Panel Replacement, Front and Back Panel: 1 단계, 이미지 1/2 HP Split 13-r010dx Front and Back Panel Replacement, Front and Back Panel: 1 단계, 이미지 2/2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Front and Back Panel Replacement: 2 단계, 이미지 1/2 HP Split 13-r010dx Front and Back Panel Replacement: 2 단계, 이미지 2/2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Front and Back Panel Replacement: 3 단계, 이미지 1/1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Front and Back Panel Replacement: 4 단계, 이미지 1/1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
결론
Kyle Jaeger
회원 가입일: 09/25/17
209 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 426
