주요 콘텐츠로 건너뛰기
HP Split 13-r010dx Hard Drive Replacement
필요한 것
  1. HP Split 13-r010dx Hard Drive Replacement, Front and Back Panel: 1 단계, 이미지 1/2 HP Split 13-r010dx Hard Drive Replacement, Front and Back Panel: 1 단계, 이미지 2/2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Hard Drive Replacement: 2 단계, 이미지 1/2 HP Split 13-r010dx Hard Drive Replacement: 2 단계, 이미지 2/2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Hard Drive Replacement: 3 단계, 이미지 1/1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Hard Drive Replacement: 4 단계, 이미지 1/1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Locate the hard drive. (The hard drive is located in the center of the device)
  6. HP Split 13-r010dx Hard Drive Replacement: 6 단계, 이미지 1/3 HP Split 13-r010dx Hard Drive Replacement: 6 단계, 이미지 2/3 HP Split 13-r010dx Hard Drive Replacement: 6 단계, 이미지 3/3
    • Locate the black strip of thermal resistant tape that is covering the upper right portion of the hard drive.
    • Gently lift up with the tape.
    • Fold the tape back away from the hard drive.
  7. HP Split 13-r010dx Hard Drive Replacement: 7 단계, 이미지 1/2 HP Split 13-r010dx Hard Drive Replacement: 7 단계, 이미지 2/2
    • Locate the four screws (Size: 4mm) at each of the four corners of the hard drive.
    • Remove the four screws using a #0 Phillips head screwdriver.
  8. HP Split 13-r010dx Hard Drive Replacement: 8 단계, 이미지 1/2 HP Split 13-r010dx Hard Drive Replacement: 8 단계, 이미지 2/2
    • Locate the lift tab. (The lift tab is located at the bottom left corner of the hard drive).
    • Gently lift up on the lift tab
    • Be cautious when lifting the hard drive from its designated slot, the hard drive is still connected to the device
  9. HP Split 13-r010dx Hard Drive Replacement: 9 단계, 이미지 1/3 HP Split 13-r010dx Hard Drive Replacement: 9 단계, 이미지 2/3 HP Split 13-r010dx Hard Drive Replacement: 9 단계, 이미지 3/3
    • Locate the connection of the hard drive to the device.
    • Gently grasp the connector cord and pull horizontally to the right. (Very little force is needed to disconnect the cord).
  10. HP Split 13-r010dx Hard Drive Replacement: 10 단계, 이미지 1/2 HP Split 13-r010dx Hard Drive Replacement: 10 단계, 이미지 2/2
    • The hard drive is no longer connected to the device. Lift the hard drive up vertically and set aside.
    • The hard drive removal is completed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kim
회원 가입일: 09/26/17
201 평판
안내서 2개 작성하였습니다
댓글 한 개
Is it possible to change the Wd5000m21k disk for a Wd5000m22k?
Pablo Cesar Zacarias - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 4,517
