주요 콘텐츠로 건너뛰기
HP Split 13-r010dx Screen Replacement
필요한 것
  1. HP Split 13-r010dx Screen Replacement, Front and Back Panel: 1 단계, 이미지 1/2 HP Split 13-r010dx Screen Replacement, Front and Back Panel: 1 단계, 이미지 2/2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Screen Replacement: 2 단계, 이미지 1/2 HP Split 13-r010dx Screen Replacement: 2 단계, 이미지 2/2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Screen Replacement: 3 단계, 이미지 1/1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Screen Replacement: 4 단계, 이미지 1/1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Screen Replacement, Screen: 5 단계, 이미지 1/3 HP Split 13-r010dx Screen Replacement, Screen: 5 단계, 이미지 2/3 HP Split 13-r010dx Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Use the PH1 screwdriver to remove eleven 4mm Phillips screws.
  6. HP Split 13-r010dx Screen Replacement: 6 단계, 이미지 1/2 HP Split 13-r010dx Screen Replacement: 6 단계, 이미지 2/2
    • Unscrew the two 2mm zero insertion force connectors. Slide aside the white wires to properly unscrew.
  7. HP Split 13-r010dx Screen Replacement: 7 단계, 이미지 1/3 HP Split 13-r010dx Screen Replacement: 7 단계, 이미지 2/3 HP Split 13-r010dx Screen Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to pull up the yellow colored display cable connector.
    • Pull it to the direction of the cable.
  8. HP Split 13-r010dx Screen Replacement: 8 단계, 이미지 1/1
    • Glue is attached at the edges. Apply force to the sides of the tablet. Separate the digitizer from the body of the tablet.
    • Replace the old screen with a new one.
    • If your screen is broken or damaged, use caution when pulling the screen from the tablet to avoid self harm.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
bushraishaq
회원 가입일: 09/25/17
327 평판
안내서 2개 작성하였습니다
댓글 한 개
Hello… How to know if it is the digitizer or the screen that is broken? .. thanks
Martin Sala - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 596
