소개
If the audio is distorted through an external speaker or another peripheral device, then the Audio port is defective. Use this guide to access, remove, and replace your Audio port.
필요한 것
Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
Remove the four 4-mm Phillips #0 screws.
Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
