주요 콘텐츠로 건너뛰기
HP Split x2 13-g210dx Back Panel Replacement
필요한 것
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Isaac Van Baren
회원 가입일: 02/26/19
315 평판
안내서 2개 작성하였습니다
댓글 한 개
How do I put the felt cover back on?
Prince Phoenix - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 390
