소개
If the laptop only powers on while plugged in, then the battery is defective. Use this guide to access, remove, and replace your battery. Separating the back panel from the clips on the device will require the use of force.
필요한 것
Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
Remove the four 4-mm Phillips #0 screws.
Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
다른 4명이 해당 안내서를 완성하였습니다.
