주요 콘텐츠로 건너뛰기
HP Split x2 Rear Cover Replacement
필요한 것
  1. HP Split x2 Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Rear Cover Replacement: 2 단계, 이미지 1/3 HP Split x2 Rear Cover Replacement: 2 단계, 이미지 2/3 HP Split x2 Rear Cover Replacement: 2 단계, 이미지 3/3
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Rear Cover Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Rear Cover Replacement: 4 단계, 이미지 1/2 HP Split x2 Rear Cover Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Rear Cover Replacement: 5 단계, 이미지 1/2 HP Split x2 Rear Cover Replacement: 5 단계, 이미지 2/2
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Ricky Huitema
회원 가입일: 09/24/15
449 평판
안내서 2개 작성하였습니다
Texas Tech, Team 22-5, Rauch Fall 2015 Texas Tech, Team 22-5, Rauch Fall 2015 회원
TTU-RAUCH-F15S22G5
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 3,874
