소개
This guide will help to assist in the removal of the HP Sprocket 2-in-1 battery. Batteries can become damage when exposed to extreme temperatures, be sure to complete this tutorial in a well lit, room temperature environment.
필요한 것
Use a JIS #00 screwdriver to remove a single black screw near the viewfinder.
Remove a single silver 2.5mm JIS #00 screw near the USB port of the device.
Carefully remove the metal bracket.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 7개
Awesome guide. Just turned on my sprocket after 9 months and the battery is definitely dead. I will definitely be using your guide in the days to come. But where did you get the replacement battery from?
Cheers,
Big Peltch - 답글
Did you ever figure out where to buy a battery?
The original post is old asking where to find a replacement battery, but hopefully this post will help those that find this installation video. Amazon has the batteries for about $26.00. Here’s a link to help out.
Replacement Battery for HP Sprocket 200,PN:1AS84-60006,Photo Printer Battery https://a.co/d/2gML4tv
Hola, donde puedo comprar la bateria de HP Sprocket 100? Li-ion Polymer Battery Model: P0562-LF. Desde ya muchas gracias.
