주요 콘텐츠로 건너뛰기
HP Sprocket 2-in-1 Outer Casing Replacement
필요한 것
  1. HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1/2 HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Outer Casing Replacement: 2 단계, 이미지 1/2 HP Sprocket 2-in-1 Outer Casing Replacement: 2 단계, 이미지 2/2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Outer Casing Replacement: 3 단계, 이미지 1/3 HP Sprocket 2-in-1 Outer Casing Replacement: 3 단계, 이미지 2/3 HP Sprocket 2-in-1 Outer Casing Replacement: 3 단계, 이미지 3/3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Outer Casing Replacement: 4 단계, 이미지 1/3 HP Sprocket 2-in-1 Outer Casing Replacement: 4 단계, 이미지 2/3 HP Sprocket 2-in-1 Outer Casing Replacement: 4 단계, 이미지 3/3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Outer Casing Replacement: 5 단계, 이미지 1/2 HP Sprocket 2-in-1 Outer Casing Replacement: 5 단계, 이미지 2/2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Outer Casing Replacement: 6 단계, 이미지 1/3 HP Sprocket 2-in-1 Outer Casing Replacement: 6 단계, 이미지 2/3 HP Sprocket 2-in-1 Outer Casing Replacement: 6 단계, 이미지 3/3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Outer Casing Replacement: 7 단계, 이미지 1/1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
결론
Kevin Steward
회원 가입일: 02/05/19
178 평판
안내서 1개 작성함
University of Michigan, Team S1-G4, Li Winter 2019 University of Michigan, Team S1-G4, Li Winter 2019 회원
UMIC-LI-W19S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 335
