주요 콘텐츠로 건너뛰기
HP Star Wars Special Edition 15-an051dx Battery Replacement
  1. HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: 1 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: 1 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the device is fully powered down and unplugged from external power.
    • Close the device and turn it over so it will be on its back.
  2. HP Star Wars Special Edition 15-an051dx Battery Replacement: 2 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Battery Replacement: 2 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Battery Replacement: 2 단계, 이미지 3/3
    • In the red is the battery and the battery's holding/locking latches.
    • Slide the latches in the direction the arrows face. This will unlock and release the battery.
    • Set the old battery aside or dispose of properly by following the manufacturers instructions written on the battery or check online of battery disposal services.
  3. HP Star Wars Special Edition 15-an051dx Battery Replacement: 3 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Battery Replacement: 3 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Battery Replacement: 3 단계, 이미지 3/3
    • Check the battery port on your device and make sure it is clear of debris and pins are not bent or damaged.
    • Install the new battery into the port and press down gently.
    • Make sure it latches on to its locking clip.
    • Once installed and you have followed the battery manufacturer's instructions, turn your device on to its upright position and boot your device.
결론
Device should be working as usual with the new battery.
다른 한 분이 해당 안내서를 완성하였습니다.
Fernando Mendez
회원 가입일: 08/25/22
643 평판
안내서 5개 작성하였습니다
Gateway, Team 1-2, Pee Fall 2022 Gateway, Team 1-2, Pee Fall 2022 회원
GCC-PEE-F22S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Altho this a simple fix some people still have a hard time removing the battery so thank you very much
RETRO GAMEHEAD - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 274
