주요 콘텐츠로 건너뛰기
HP Star Wars Special Edition 15-an051dx Hard Drive Replacement
필요한 것
  1. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure the device is fully powered down and unplugged from external power.
    • Close the device and turn it over so it will be on its back.
  2. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • In the red is the battery and the battery's holding/locking latches.
    • Slide the latches in the direction the arrows face. This will unlock and release the battery.
    • Set the old battery aside or dispose of properly by following the manufacturers instructions written on the battery or check online of battery disposal services.
  3. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Check the battery port on your device and make sure it is clear of debris and pins are not bent or damaged.
    • Install the new battery into the port and press down gently.
    • Make sure it latches on to its locking clip.
    • Once installed and you have followed the battery manufacturer's instructions, turn your device on to its upright position and boot your device.
  4. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement, HDD/SSD: 4 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement, HDD/SSD: 4 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement, HDD/SSD: 4 단계, 이미지 3개 중 3개
    • Ensure that the laptop is completely powered off and unplugged from any power source from the beginning.
    • Slide the battery release tabs to the left, and then remove the battery.
    • Using a Philips #1 screwdriver, remove the following screws from the base panel:
    • Two 12.5 mm screws
    • Four 5.5 mm screws and six 7.25 mm screws
    • Organize and make sure to label the screws by size and location for easy reassembly.
    • Gently remove the two corner panels located at each end of the batteru slot to reveal an additional screw under each panel.
    • Locate and then remove the six remaining 7.25 mm screws hidden in the battery compartment and also beneath the corner panel covers.
  5. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the optical drive by pulling on the plastic cover panel.
    • Using a prying tool, gently pry the back panel off.
    • Start with the device's corners and carefully slide the tool towards the middle, lifting the panel as you go.
  6. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Lift The Drive
    • Gently lift the left side of the hard drive to detach it from the mounting bay.
    • The drive will have two rubber pieces on its side that helps it stay mounted on the device.
    • Detach Rubber Mounts
    • Gently pull the rubber mounts away from the drive to release it.
    • Disconnect the Cable:
    • Locate the plastic tab on the connecting table.
    • Carefully pry the tab upward to disconnect the cable from the hard drive. Avoid pulloing the cable directly to prevent damage.
  7. HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Star Wars Special Edition 15-an051dx Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Observe the port connection and match it with the drives slot.
    • Connect and press firmly.
    • Install black rubber pieces on to the drive.
    • Place the drive into its slot.
    • Install the drive by placing the end with connectors in first, then gently pushing the other end down into its slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Fernando Mendez
회원 가입일: 08/25/22
643 평판
안내서 5개를 작성함
Gateway, Team 1-2, Pee Fall 2022 Gateway, Team 1-2, Pee Fall 2022 회원
GCC-PEE-F22S1G2
4 회원들
안내서 5개를 작성함
1가이드 댓글
Que slot é aquele
FBOUXO - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 923
