주요 콘텐츠로 건너뛰기
HP Star Wars Special Edition 15-an051dx Screen Replacement
필요한 것
  1. HP Star Wars Special Edition 15-an051dx Screen Replacement, Screen: 1 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Screen Replacement, Screen: 1 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Make sure the laptop is fully powered down and unplugged before you start.
    • Remove the two circular plastic screw covers, then remove the two 4.5 mm screws in the using a Phillips #1 screwdriver.
  2. HP Star Wars Special Edition 15-an051dx Screen Replacement: 2 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 2 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 2 단계, 이미지 3/3
    • Insert a spudger in between the bezel and display, at the top.
    • Move the tool around all sides of the bezel.
    • With your finger, lift the inside part of the bezel.
    • Pull the bezel back; it will pop-off.
  3. HP Star Wars Special Edition 15-an051dx Screen Replacement: 3 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 3 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 3 단계, 이미지 3/3
    • Remove the four 2.75 mm screws using a Phillips #1 screwdriver
    • Lift the screen using a spudger.
  4. HP Star Wars Special Edition 15-an051dx Screen Replacement: 4 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 4 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 4 단계, 이미지 3/3
    • Lifting the tape on the back of the screen and peel it off.
    • Remove the connection.
  5. HP Star Wars Special Edition 15-an051dx Screen Replacement: 5 단계, 이미지 1/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 5 단계, 이미지 2/3 HP Star Wars Special Edition 15-an051dx Screen Replacement: 5 단계, 이미지 3/3
    • Connect the new screen using the 30 pin cable.
    • Put the screen in place.
결론
Enjoy your new screen!
다른 2명이 해당 안내서를 완성하였습니다.
Fernando Mendez
회원 가입일: 08/25/22
643 평판
안내서 5개 작성하였습니다
Gateway, Team 1-2, Pee Fall 2022 Gateway, Team 1-2, Pee Fall 2022 회원
GCC-PEE-F22S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 227
