주요 콘텐츠로 건너뛰기
HP Stream 11-d008TU Heatsink Replacement
필요한 것
  1. HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: 1 단계, 이미지 1/3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: 1 단계, 이미지 2/3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: 1 단계, 이미지 3/3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Heatsink Replacement, Screw removal: 2 단계, 이미지 1/2 HP Stream 11-d008TU Heatsink Replacement, Screw removal: 2 단계, 이미지 2/2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: 3 단계, 이미지 1/3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: 3 단계, 이미지 2/3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: 3 단계, 이미지 3/3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: 4 단계, 이미지 1/3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: 4 단계, 이미지 2/3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: 4 단계, 이미지 3/3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Heatsink Replacement, Unscrew the heatsink: 5 단계, 이미지 1/1
    • Unscrew the four 2.5mm M2x2.5 PH-0 Phillips head screws in reverse numerical order (4-3-2-1)
    • 4: Bottom left | 3: Top Right | 2: Bottom Right | 1: Top Left
  6. HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: 6 단계, 이미지 1/2 HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: 6 단계, 이미지 2/2
    • Lift the heatsink
결론
다른 한 분이 해당 안내서를 완성하였습니다.
CONVERSION
회원 가입일: 03/07/20
1,252 평판
안내서 8개 작성하였습니다
Australia Australia 회원
Community
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 70
