소개
Sometimes the keyboard of an HP Stream 11-d010nr will start to behave sub optimally, such as unresponsive or sticky keys. This guide will show you how to replace it.
필요한 것
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
I feel like the 5-10 minutes estimated time is way too short for this repair (however, I have not done this, and may be wrong).
There will definitely be variation depending on each individual but our group came to the conclusion that this was a reasonable time frame. I appreciate the feedback though and if anyone else reaches out saying it is too short I will increase the estimated time. Thank you!
