주요 콘텐츠로 건너뛰기
HP Stream 11-d010nr Speaker Replacement
필요한 것
  1. HP Stream 11-d010nr Speaker Replacement, Keyboard: 1 단계, 이미지 1/2 HP Stream 11-d010nr Speaker Replacement, Keyboard: 1 단계, 이미지 2/2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Speaker Replacement: 3 단계, 이미지 1/2 HP Stream 11-d010nr Speaker Replacement: 3 단계, 이미지 2/2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Speaker Replacement: 4 단계, 이미지 1/1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Speaker Replacement: 5 단계, 이미지 1/3 HP Stream 11-d010nr Speaker Replacement: 5 단계, 이미지 2/3 HP Stream 11-d010nr Speaker Replacement: 5 단계, 이미지 3/3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Speaker Replacement: 6 단계, 이미지 1/1
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • Undo 4 3mm screws attached to the speaker.
  8. HP Stream 11-d010nr Speaker Replacement: 8 단계, 이미지 1/1
    • Remove connecting wire from the Motherboard.
  9. HP Stream 11-d010nr Speaker Replacement: 9 단계, 이미지 1/1
    • Extract speakers after disconnecting.
결론
Tristan Thompson
회원 가입일: 10/03/22
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 104
