소개
If your HP Stream 11-d010nr is showing signs of a faulty or damaged wifi chip, such as being unable to consistently connect to a wifi signal, its wifi card may need to be replaced. This guide will show you the steps needed to do so.
필요한 것
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Remove any tape holding the battery connector in place.
Using your fingers, carefully unplug the battery.
다른 한 분이 해당 안내서를 완성하였습니다.
