주요 콘텐츠로 건너뛰기
HP Stream 11-d020nr Battery Replacement
필요한 것
  1. HP Stream 11-d020nr Battery Replacement, Lower Case: 1 단계, 이미지 1/3 HP Stream 11-d020nr Battery Replacement, Lower Case: 1 단계, 이미지 2/3 HP Stream 11-d020nr Battery Replacement, Lower Case: 1 단계, 이미지 3/3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Battery Replacement: 2 단계, 이미지 1/2 HP Stream 11-d020nr Battery Replacement: 2 단계, 이미지 2/2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Battery Replacement: 3 단계, 이미지 1/3 HP Stream 11-d020nr Battery Replacement: 3 단계, 이미지 2/3 HP Stream 11-d020nr Battery Replacement: 3 단계, 이미지 3/3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Battery Replacement: 4 단계, 이미지 1/3 HP Stream 11-d020nr Battery Replacement: 4 단계, 이미지 2/3 HP Stream 11-d020nr Battery Replacement: 4 단계, 이미지 3/3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Battery Replacement, Keyboard: 5 단계, 이미지 1/2 HP Stream 11-d020nr Battery Replacement, Keyboard: 5 단계, 이미지 2/2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
  6. HP Stream 11-d020nr Battery Replacement: 6 단계, 이미지 1/3 HP Stream 11-d020nr Battery Replacement: 6 단계, 이미지 2/3 HP Stream 11-d020nr Battery Replacement: 6 단계, 이미지 3/3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
  7. HP Stream 11-d020nr Battery Replacement, Battery: 7 단계, 이미지 1/2 HP Stream 11-d020nr Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Remove any tape covering the battery connector.
    • Disconnect the battery cable from its socket on the motherboard.
  8. HP Stream 11-d020nr Battery Replacement: 8 단계, 이미지 1/3 HP Stream 11-d020nr Battery Replacement: 8 단계, 이미지 2/3 HP Stream 11-d020nr Battery Replacement: 8 단계, 이미지 3/3
    • Unscrew the four 3.3mm Phillips #000 screws.
    • Lift the battery out gently.
결론
다른 22명이 해당 안내서를 완성하였습니다.
Spenser Mason
회원 가입일: 02/04/16
1,763 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G5
5 회원들
안내서 19개 작성하였습니다
댓글 4개
Thank you for the guide. For us it was enough to unplug the battery and then plug it back in. The problem we encountered was that the capslock would blink on startup for the HP Stream 11.
ruudvanleeuwen - 답글
Would this fix work for a HP notebook Model 11-N012NA. ?
Denis Mahony - 답글
Would this work for my House notebook PC 11-d011wm?
If I put the charger the thing will Will just start blinking
Abdul Rahman - 답글
Worked fine but I didn’t need to unplug the ribbon cables. Merely had to lean the keyboard against the screen and remove the battery.
Would advise taking a picture of the ribbon cables to make sure they are in far enough on completion.
des.lyde - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 60
전체 시간: 48,521
