주요 콘텐츠로 건너뛰기
HP Stream 11-d020nr Lower Case Replacement
필요한 것
  1. HP Stream 11-d020nr Lower Case Replacement, Lower Case: 1 단계, 이미지 1/3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: 1 단계, 이미지 2/3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: 1 단계, 이미지 3/3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lower Case Replacement: 2 단계, 이미지 1/2 HP Stream 11-d020nr Lower Case Replacement: 2 단계, 이미지 2/2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lower Case Replacement: 3 단계, 이미지 1/3 HP Stream 11-d020nr Lower Case Replacement: 3 단계, 이미지 2/3 HP Stream 11-d020nr Lower Case Replacement: 3 단계, 이미지 3/3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lower Case Replacement: 4 단계, 이미지 1/3 HP Stream 11-d020nr Lower Case Replacement: 4 단계, 이미지 2/3 HP Stream 11-d020nr Lower Case Replacement: 4 단계, 이미지 3/3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ian Somerville
회원 가입일: 03/10/16
122 평판
안내서 1개 작성함
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G5
5 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 1,638
