주요 콘텐츠로 건너뛰기
HP Stream 11-r014wm Screen Replacement
필요한 것
  1. HP Stream 11-r014wm Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 HP Stream 11-r014wm Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Use a plastic spudger to remove two oblong screw covers on the bottom of the computer.
    • Use a plastic spudger to remove four rubber feet.
    • To remove the feet you must break the glue seal holding them down.
  2. HP Stream 11-r014wm Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eleven 5 millimeter housing screws from the bottom of the computer using a #00 Phillips head screwdriver.
  3. HP Stream 11-r014wm Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Stream 11-r014wm Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the computer over and open it.
    • Use a plastic spudger to pry the keyboard bezel away from the base. Pry around the edge, being careful not to jam the spudger too far underneath the bezel (potentially damaging internal components).
    • The bezel is tightest near the hinge.
    • Once the bezel is free, do not lift it away from the base.
  4. HP Stream 11-r014wm Screen Replacement: 4 단계, 이미지 2개 중 1개 HP Stream 11-r014wm Screen Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Identify two ribbon connectors and the ZIF cable underneath the keyboard.
    • Use tweezers to disconnect both ribbon cables and the ZIF connector.
  5. HP Stream 11-r014wm Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove five 4 millimeter hinge-screws using a #00 Phillips head screwdriver.
    • There are three 4 millimeter hinge-screws on the right side.
  6. HP Stream 11-r014wm Screen Replacement: 6 단계, 이미지 2개 중 1개 HP Stream 11-r014wm Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect the black power cable.
    • Remove the 3.5 millimeter screw from the WiFi chip using a #00 Phillips head screwdriver.
    • The upper and lower halves of the laptop should now be separated.
  7. HP Stream 11-r014wm Screen Replacement: 7 단계, 이미지 2개 중 1개 HP Stream 11-r014wm Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove two 2 millimeter bezel screws using a #00 Phillips screwdriver.
    • Use a plastic spudger to pry the bezel away from the screen.
    • The bezel screws are covered by thin plastic.
  8. HP Stream 11-r014wm Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove four 3 millimeter screen screws using a #00 Phillips head screwdriver.
    • Lift the screen with steady pressure until the glue seal breaks and releases the lid.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Anthony R Cardinali
회원 가입일: 04/05/18
988 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 1,104
