주요 콘텐츠로 건너뛰기
HP Stream 11-r020nr Keyboard Panel Replacement
필요한 것
  1. HP Stream 11-r020nr Keyboard Panel Replacement, Keyboard Panel: 1 단계, 이미지 2개 중 1개 HP Stream 11-r020nr Keyboard Panel Replacement, Keyboard Panel: 1 단계, 이미지 2개 중 2개
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr Keyboard Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr Keyboard Panel Replacement: 3 단계, 이미지 2개 중 1개 HP Stream 11-r020nr Keyboard Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr Keyboard Panel Replacement: 4 단계, 이미지 2개 중 1개 HP Stream 11-r020nr Keyboard Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr Keyboard Panel Replacement: 5 단계, 이미지 2개 중 1개 HP Stream 11-r020nr Keyboard Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr Keyboard Panel Replacement: 6 단계, 이미지 2개 중 1개 HP Stream 11-r020nr Keyboard Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr Keyboard Panel Replacement: 7 단계, 이미지 1개 중 1개
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Will Calligan
회원 가입일: 04/09/18
217 평판
안내서 1개를 작성함
1가이드 댓글
Hello, I have an hp stream 11 inch laptop and would like to know how do you remove the keys from the keyboard to replace the palmrest or key board cover?
keisha manley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 1,887
