주요 콘텐츠로 건너뛰기
HP Stream 11-y010nr Keyboard Replacement
필요한 것
  1. HP Stream 11-y010nr Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Keyboard Replacement: 2 단계, 이미지 1/2 HP Stream 11-y010nr Keyboard Replacement: 2 단계, 이미지 2/2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Keyboard Replacement: 3 단계, 이미지 1/2 HP Stream 11-y010nr Keyboard Replacement: 3 단계, 이미지 2/2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Keyboard Replacement: 4 단계, 이미지 1/1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Keyboard Replacement: 5 단계, 이미지 1/3 HP Stream 11-y010nr Keyboard Replacement: 5 단계, 이미지 2/3 HP Stream 11-y010nr Keyboard Replacement: 5 단계, 이미지 3/3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
결론
To reassemble your device, follow these instructions.
Adam Sitzmann
회원 가입일: 01/26/20
914 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 488
