주요 콘텐츠로 건너뛰기
HP Stream 11-y010nr Screen Replacement
필요한 것
  1. HP Stream 11-y010nr Screen Replacement, Keyboard: 1 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement, Keyboard: 1 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement, Keyboard: 1 단계, 이미지 3/3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Screen Replacement: 2 단계, 이미지 1/2 HP Stream 11-y010nr Screen Replacement: 2 단계, 이미지 2/2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Screen Replacement: 3 단계, 이미지 1/2 HP Stream 11-y010nr Screen Replacement: 3 단계, 이미지 2/2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Screen Replacement: 4 단계, 이미지 1/1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Screen Replacement: 5 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement: 5 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement: 5 단계, 이미지 3/3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Screen Replacement, Screen: 6 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement, Screen: 6 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement, Screen: 6 단계, 이미지 3/3
    • Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
  7. HP Stream 11-y010nr Screen Replacement: 7 단계, 이미지 1/2 HP Stream 11-y010nr Screen Replacement: 7 단계, 이미지 2/2
    • Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
  8. HP Stream 11-y010nr Screen Replacement: 8 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement: 8 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement: 8 단계, 이미지 3/3
    • Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Screen Replacement: 9 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement: 9 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement: 9 단계, 이미지 3/3
    • Remove the bezel by pulling upwards on the left bottom corner.
  10. HP Stream 11-y010nr Screen Replacement: 10 단계, 이미지 1/2 HP Stream 11-y010nr Screen Replacement: 10 단계, 이미지 2/2
    • Disconnect the screen from the motherboard by pulling the display cable from its connector.
  11. HP Stream 11-y010nr Screen Replacement: 11 단계, 이미지 1/1
    • Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
  12. HP Stream 11-y010nr Screen Replacement: 12 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement: 12 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement: 12 단계, 이미지 3/3
    • Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
  13. HP Stream 11-y010nr Screen Replacement: 13 단계, 이미지 1/3 HP Stream 11-y010nr Screen Replacement: 13 단계, 이미지 2/3 HP Stream 11-y010nr Screen Replacement: 13 단계, 이미지 3/3
    • Take the tweezers and push up on the small connector to the left of the webcam.
  14. HP Stream 11-y010nr Screen Replacement: 14 단계, 이미지 1/2 HP Stream 11-y010nr Screen Replacement: 14 단계, 이미지 2/2
    • Gently pull the cord out from around the screen area.
  15. HP Stream 11-y010nr Screen Replacement: 15 단계, 이미지 1/2 HP Stream 11-y010nr Screen Replacement: 15 단계, 이미지 2/2
    • Remove the screen with the display cable attached.
결론
Adam Sitzmann
회원 가입일: 01/26/20
914 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 467
