주요 콘텐츠로 건너뛰기
HP Stream 13 Disassembly for Upgrading the PCIe mini SSD
필요한 것
  1. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Starting out: 1 단계, 이미지 1개 중 1개
    • Make sure that you take your laptop apart in an area that has lots of light and are discharged. Touch something to ground yourself before starting! Electrostatic damage can fry your motherboard.
  2. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Flip laptop over: 2 단계, 이미지 2개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Flip laptop over: 2 단계, 이미지 2개 중 2개
    • Flip your laptop over. There are four pads that you need to remove to access the screws. Remove the center pad first as shown in the picture.
  3. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD: 3 단계, 이미지 3개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD: 3 단계, 이미지 3개 중 2개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD: 3 단계, 이미지 3개 중 3개
    • Beneath each pad is a screw. Make sure you remove all of the pads.
  4. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Use a screwdriver to remove the keyboard assembly: 4 단계, 이미지 2개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Use a screwdriver to remove the keyboard assembly: 4 단계, 이미지 2개 중 2개
    • There will be a total of 3 cables to unplug. Flip each ZIF upward to unplug.
  5. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Bottom of Keyboard: 5 단계, 이미지 3개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Bottom of Keyboard: 5 단계, 이미지 3개 중 2개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Bottom of Keyboard: 5 단계, 이미지 3개 중 3개
    • Insert wisdom here.
  6. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Identify the wifi/bluetooth mPCIe card.: 6 단계, 이미지 1개 중 1개
    • The WiFi/Bluetooth mPCIe card is located to the right of the motherboard, highlighted with the arrow.
  7. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Close up of the WiFi and WWAN ports: 7 단계, 이미지 2개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Close up of the WiFi and WWAN ports: 7 단계, 이미지 2개 중 2개
    • You'll notice that there is a large gap for the WWAN card and no M.2 connection. It is possible to extend the mPCIe card and remove the WiFi card completely. Another option might be to purchase a board with an M.2 WWAN card and swap it out with an SSD. Unfortunately these are quite rare.
  8. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, USB / WWAN Board: 8 단계, 이미지 3개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, USB / WWAN Board: 8 단계, 이미지 3개 중 2개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, USB / WWAN Board: 8 단계, 이미지 3개 중 3개
    • A close up of the USB WWAN Board.
  9. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, mPCIe Card: 9 단계, 이미지 2개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, mPCIe Card: 9 단계, 이미지 2개 중 2개
    • As stated before, you can swap this card out with a half-width PCIe SSD found on Amazon or other electronics retailers.
  10. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Replace thermal paste: 10 단계, 이미지 2개 중 1개 HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Replace thermal paste: 10 단계, 이미지 2개 중 2개
    • A common issue might be heat dissipation, so it's good practice to remove the stock thermal paste and replace it with better quality. I also recommend adding heat pads to the bottom of the copper heatsink where the RAM chips sit.
  11. HP Stream 13 Disassembly for Upgrading the PCIe mini SSD, Put it all back together.: 11 단계, 이미지 1개 중 1개
    • Follow the steps in reverse to put your HP Stream back the way you found it!
결론
다른 52명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Kevin Fessler
회원 가입일: 01/31/16
1,873 평판
안내서 2개를 작성함
39가이드 댓글
half-width mSATA SSD available in boot?
basicmail3 - 답글
Questo è il problema!!!
Sicuro che tale scheda possa funzionare al Boot del PC.
Bisognerebbe provare potresti dire, 53 $ per la scheda da 64 Gb + 20-30 $ per una penna USB WiFi, tot 80-90 $, e se poi non parte?
bye
That is the question!!!
Sure that this card will work at Boot the PC.
You should try to say, $ 53 for 64 GB card + 20-30 $ for a WiFi USB stick, tot 80-90 $, and if not then part?
bye
Gian Lorenzo Molinari -
Non ci fai vedere come è questa scheda SSD da mettere al posto del modulo WiFi
E poi questa scheda half-width mSATA SSD è possibile farla partire al boot?
E neppure so dove trovarle
Do not you show us how this SD card to put in place the WiFi module.
I've never seen nor know where to find them.
And then this half-width mSATA SSD card, you can start it at boot?
Gian Lorenzo Molinari - 답글
I already have a wi-fi card and I ordered hard drive 120Gb for 53$ . 20 days I'll write how it works or not
basicmail3 -
Make sure that you order an *PCIe* mini half-width or full-width (buy or make an extension bracket) and you have the current BIOS (HP sometimes whitelists cards).
Be forewarned- Not all mSATA cards will play nice with this slot. I personally recommend the Samsung PM830 128GB SSD HDD Mini PCIe from Amazon for only $40. Word of wisdom, you may have to reconnect the battery for Windows to recognize it.
Kevin Fessler -
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 66
지난 30일: 444
전체 시간: 146,211
