주요 콘텐츠로 건너뛰기
HP Stream 13-c002dx Battery Replacement
필요한 것
  1. HP Stream 13-c002dx Battery Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Stream 13-c002dx Battery Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Battery Replacement: 2 단계, 이미지 3개 중 1개 HP Stream 13-c002dx Battery Replacement: 2 단계, 이미지 3개 중 2개 HP Stream 13-c002dx Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
  3. HP Stream 13-c002dx Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #0 to remove four screws from the top of the battery labeled A.
    • Use the Phillips #0 screwdriver to remove four screws labeled holding the battery to the case.
  4. HP Stream 13-c002dx Battery Replacement: 4 단계, 이미지 2개 중 1개 HP Stream 13-c002dx Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Coming from the upper middle of the battery, there are cables which connect the battery to the motherboard. Gently remove this group of cables from the socket that it is in on the motherboard.
    • Lift the battery out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Matthew Dodge
회원 가입일: 01/23/18
416 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 3,236
