주요 콘텐츠로 건너뛰기
HP Stream 13-c002dx Keyboard Replacement
필요한 것
  1. HP Stream 13-c002dx Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 HP Stream 13-c002dx Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Keyboard Replacement: 2 단계, 이미지 1/3 HP Stream 13-c002dx Keyboard Replacement: 2 단계, 이미지 2/3 HP Stream 13-c002dx Keyboard Replacement: 2 단계, 이미지 3/3
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
결론
Matthew Dodge
회원 가입일: 01/23/18
416 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 769
