소개
This guide covers the accessing and replacing of the wireless card in an HP Stream 13-c002dx.
필요한 것
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
Once the wire is removed, set it aside so it does not get damaged.
다른 한 분이 해당 안내서를 완성하였습니다.
