주요 콘텐츠로 건너뛰기
HP Stream 13-c010nr Disassembly
필요한 것
  1. HP Stream 13-c010nr Disassembly, HP Stream 13-c010nr Disassembly: 1 단계, 이미지 1/1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Disassembly: 2 단계, 이미지 1/2 HP Stream 13-c010nr Disassembly: 2 단계, 이미지 2/2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Disassembly: 3 단계, 이미지 1/2 HP Stream 13-c010nr Disassembly: 3 단계, 이미지 2/2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Disassembly: 4 단계, 이미지 1/1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Keegan Lapham
회원 가입일: 02/22/18
759 평판
안내서 6개 작성하였습니다
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 71
전체 시간: 3,536
