주요 콘텐츠로 건너뛰기
HP Stream 13-c110nr Keyboard Assembly Replacement
필요한 것
  1. HP Stream 13-c110nr Keyboard Assembly Replacement, Keyboard Assembly: 1 단계, 이미지 1개 중 1개
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Keyboard Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Keyboard Assembly Replacement: 3 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Keyboard Assembly Replacement: 3 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Keyboard Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Keyboard Assembly Replacement: 4 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Keyboard Assembly Replacement: 4 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Keyboard Assembly Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Keyboard Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Keyboard Assembly Replacement: 6 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Keyboard Assembly Replacement: 6 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Keyboard Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Keyboard Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Keyboard Assembly Replacement: 8 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Keyboard Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Keyboard Assembly Replacement: 9 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Keyboard Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Keyboard Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the Keyboard/Top Cover from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Stacey Deel
회원 가입일: 01/31/19
1,147 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 400
