주요 콘텐츠로 건너뛰기
HP Stream 13-c110nr Motherboard Replacement
필요한 것
  1. HP Stream 13-c110nr Motherboard Replacement, Keyboard Assembly: 1 단계, 이미지 1개 중 1개
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Motherboard Replacement: 4 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 4 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Motherboard Replacement: 8 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Motherboard Replacement, WLAN Module: 11 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement, WLAN Module: 11 단계, 이미지 2개 중 2개
    • Disconnect the WLAN antenna cable from the WLAN module.
  12. HP Stream 13-c110nr Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove one (1) Phillips P0 PM2.0x3.0 mm screw.
    • Place one (1) screw on magnetic mat for reassembly.
  13. HP Stream 13-c110nr Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the WLAN Module from device.
  14. HP Stream 13-c110nr Motherboard Replacement, Battery Assembly: 14 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement, Battery Assembly: 14 단계, 이미지 2개 중 2개
    • Use a pick to detach the Battery assembly cable.
  15. HP Stream 13-c110nr Motherboard Replacement: 15 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  16. HP Stream 13-c110nr Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove Battery Assembly from device.
  17. HP Stream 13-c110nr Motherboard Replacement, USB/Card Reader Board: 17 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement, USB/Card Reader Board: 17 단계, 이미지 2개 중 2개
    • Use a pick to disconnect the USB/Card Reader cable from the System Board.
  18. HP Stream 13-c110nr Motherboard Replacement: 18 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Remove three (3) Phillips P0 PM2.0x3.0 mm screws.
    • Place three (3) screws on magnetic mat for reassembly.
  19. HP Stream 13-c110nr Motherboard Replacement: 19 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Remove the USB/Card Reader board assembly from the device.
  20. HP Stream 13-c110nr Motherboard Replacement, Heat Sink: 20 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement, Heat Sink: 20 단계, 이미지 2개 중 2개
    • Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
    • Place two (2) screws on magnetic mat for reassembly.
  21. HP Stream 13-c110nr Motherboard Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the Heat Sink from the System Board.
  22. HP Stream 13-c110nr Motherboard Replacement, Motherboard: 22 단계, 이미지 1개 중 1개
    • Disconnect the Display Cable.
  23. HP Stream 13-c110nr Motherboard Replacement: 23 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 23 단계, 이미지 2개 중 2개
    • Disconnect the Speaker Cable.
  24. HP Stream 13-c110nr Motherboard Replacement: 24 단계, 이미지 3개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 24 단계, 이미지 3개 중 2개 HP Stream 13-c110nr Motherboard Replacement: 24 단계, 이미지 3개 중 3개
    • Remove five (5) Phillips P0 PM2.5x3.0 mm screws from System Board assembly.
    • Place five (5) screws on magnetic mat for reassembly.
  25. HP Stream 13-c110nr Motherboard Replacement: 25 단계, 이미지 2개 중 1개 HP Stream 13-c110nr Motherboard Replacement: 25 단계, 이미지 2개 중 2개
    • Lift the right side of the System Board and slide it from the device.
결론
작성자
4다른 기여자 명과 함께
Stacey Deel
회원 가입일: 01/31/19
1,147 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 647
