주요 콘텐츠로 건너뛰기
HP Stream 14-CB174WM RAM Replacement
필요한 것
  1. HP Stream 14-CB174WM RAM Replacement, Lower Case: 1 단계, 이미지 1/2 HP Stream 14-CB174WM RAM Replacement, Lower Case: 1 단계, 이미지 2/2
    • Use an opening pick to gently pry up the edge of the rubber foot.
    • Grab the lifted edge of the foot and gently pull it away.
    • Repeat for the other rubber foot.
    • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
  2. HP Stream 14-CB174WM RAM Replacement: 2 단계, 이미지 1/2 HP Stream 14-CB174WM RAM Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
  3. HP Stream 14-CB174WM RAM Replacement: 3 단계, 이미지 1/3 HP Stream 14-CB174WM RAM Replacement: 3 단계, 이미지 2/3 HP Stream 14-CB174WM RAM Replacement: 3 단계, 이미지 3/3
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
    • You will hear "snaps" of the lower case retaining clips releasing.
    • Continue prying around the entire perimeter until the lower case fully releases.
    • Lift off the lower case.
  4. HP Stream 14-CB174WM RAM Replacement, RAM: 4 단계, 이미지 1/2 HP Stream 14-CB174WM RAM Replacement, RAM: 4 단계, 이미지 2/2
    • There are spring-loaded metal clips on each side of the RAM stick. Place your fingers on each metal clip and push them to the side.
    • The RAM will lift a few millimeters; this is normal.
  5. HP Stream 14-CB174WM RAM Replacement: 5 단계, 이미지 1/1
    • Pull the RAM module directly out of its slot.
    • Only handle the RAM by its edges. Skin oils can damage the component and dirty its gold contacts.
결론
Daniel Pickett
회원 가입일: 02/15/24
578 평판
안내서 4개 작성하였습니다
University of Memphis, Team 2-1, Sneed Spring 2024 University of Memphis, Team 2-1, Sneed Spring 2024 회원
UM-SNEED-S24S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 57
