주요 콘텐츠로 건너뛰기
HP Stream 8 Display Panel Cable Replacement
필요한 것
  1. HP Stream 8 Display Panel Cable Replacement, Display Panel Cable: 1 단계, 이미지 1/1
    • Use your nail to pry up the back cover of the device.
  2. HP Stream 8 Display Panel Cable Replacement: 2 단계, 이미지 1/1
    • Fully remove the back cover.
  3. HP Stream 8 Display Panel Cable Replacement: 3 단계, 이미지 1/3 HP Stream 8 Display Panel Cable Replacement: 3 단계, 이미지 2/3 HP Stream 8 Display Panel Cable Replacement: 3 단계, 이미지 3/3
    • Remove the 10 3mm screws using the Phillips #00 screwdriver.
  4. HP Stream 8 Display Panel Cable Replacement: 4 단계, 이미지 1/2 HP Stream 8 Display Panel Cable Replacement: 4 단계, 이미지 2/2
    • Pry up the inside cover the same way as you did with the back cover.
  5. HP Stream 8 Display Panel Cable Replacement: 5 단계, 이미지 1/1
    • Remove the USB flex ribbon cable from the connection point.
  6. HP Stream 8 Display Panel Cable Replacement: 6 단계, 이미지 1/2 HP Stream 8 Display Panel Cable Replacement: 6 단계, 이미지 2/2
    • Carefully disconnect the display panel cable from the system board.
  7. HP Stream 8 Display Panel Cable Replacement: 7 단계, 이미지 1/1
    • Remove the display panel cable.
결론
Ashley Eimers
회원 가입일: 04/01/19
265 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Harley Spring 2019 IUPUI, Team S1-G3, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 305
