필요한 것
Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
Carefully remove the battery connector from the system board using the tweezers.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
