소개
This guide will provide the steps to successfully remove and replace the battery for the HP Stream x360 laptop.
필요한 것
Flip the laptop upside down then remove the seven 6.5 mm screws using a JIS J0 screwdriver.
Also remove the two 8.5 mm JIS J0 screws near the hinge of the laptop.
Peel back the two rubber feet near the hinge of the laptop to reveal and remove two more 8.5 mm JIS J0 screws.
다른 5명이 해당 안내서를 완성하였습니다.
